Tow/Haul mode - Page 2 - Chevy Colorado & GMC Canyon
 26Likes
post #21 of 54 (permalink) Old 05-12-2019, 05:29 PM
Administrator
Blue15ColoradoLT's Avatar
I dont use it all the time but I had my truck tuned so I have my primary tune which gives me the most performance while keeping stock economy on my normal setting and then my secondary tune which is balls to the wall, full on performance camaro tune on my tow/haul setting.
2015 Laser Blue Colorado LT
CC, 4X4, V6, SB
LED light bar - 32"
HID headlights
LED everything
Switchback front turn signal lights
cargo light turn signal conversion
LED Anzo tail lights
Red painted calipers
Supermod ported throttle body
Silver metallic rally stripes with red metallic pin stripe
Super Skidz skid plate
Volant CAI
Custom Katzkin leather seats
***NOTE***
SITE RULES
Blue15ColoradoLT is offline
post #22 of 54 (permalink) Old 05-12-2019, 08:21 PM
Maybe some 6 speeds are different but mine will take off from a dead stop in manual 2nd gear and accelerate to 35-40 mph without a single shift and with no strain at all.
Tommyl is offline
post #23 of 54 (permalink) Old 05-14-2019, 03:37 PM
Can Not Lock Out 1st
Actually, I think in 2nd gear it does lock out 1st. I seem to remember someone reporting that before.
Sorry, owners manual says different, 2017 Owners Manual:
When the shift lever is moved from D (Drive) to M(Manual Mode), a number displays next to the M, indicating the current transmission range. This number is the highest gear that the transmission will command while operating in M (Manual Mode). All gears below that number are available.
As driving conditions change, the transmission can automatically shift to lower gears.
For example, when 5 (Fifth) is selected, 1 (First) through 5 (Fifth) gears are automatically shifted by the transmission, but 6 (Sixth) cannot be used until the plus/minus button on the shift lever is used to change to the range.
Many FWD sedans do have a 'snow mode' feature which will lock out 1st when 2nd is selected. But not our 6-speed & 8-speed automatics.
2017 Z71 ExCab V6 4x4
Factory Trailer Brake Controller
MuttonChops is offline
post #24 of 54 (permalink) Old 05-14-2019, 04:11 PM
Well, I checked out my truck yesterday in a traffic jam and my 6 speed locks in 2nd gear when you put it in manual and select 2nd.
My 2015 Owner's Manual has same language as your 2017, but for 2015, it is wrong.
Found this in my 2015 Canyon owner manual and the 2019 Silverado owner manual (was looking to see what 10 speed did, owner's manual had same language as @MuttonChops posted.
Low Traction Mode
If equipped, Low Traction Mode assists in vehicle acceleration when
road conditions are slippery, such as with ice or snow. While the
vehicle is at a stop, select L2 using Range Selection Mode. This will
limit torque to the wheels and help prevent the tires from spinning.
post #25 of 54 (permalink) Old 05-15-2019, 07:55 AM
I was referring to a 2016 6 speed.
It may resort to using 1st when you have selected 2nd if you are taking off on a hill and it senses too much load for 2nd.
I use M mode and 2nd, 3rd, 4th as my around town "sport" mode every day.
Period.
Tommyl is offline
post #26 of 54 (permalink) Old 05-15-2019, 08:36 AM
Related to the reason comments in this thread the July Truck Trend tests the new Blazer. The author of the article was disappointed with the lack of paddle shifters (as am I), but then "discovered" using L and the controls on the gear lever. Somewhat amazing to me that would be a new discovery for them. Not something I'd want to admit if I were in their position.
CaryBosse likes this.
Goodspike is offline
post #27 of 54 (permalink) Old 05-18-2019, 08:49 AM
How do you guys highlight the post you want to reply to?
Tommyl is offline
post #28 of 54 (permalink) Old 05-18-2019, 09:01 AM
monteholic's Avatar
use the "quote" at the bottom right
2019 ZR2 Dusk Edition
2003 LS1 Corvette
1971 Monte Carlo SS454
monteholic is offline
post #29 of 54 (permalink) Old 05-18-2019, 12:00 PM
There is nothing bottom right.
This is an older android so ....
Thanks for your reply though
Tommyl is offline
post #30 of 54 (permalink) Old 05-19-2019, 11:17 AM
Cwilt's Avatar
Check the box with the comment you want to quote next to the post #. Then a quote box appears on top, tap on the quote symbol then it takes you "post reply to:" page.
Cwilt is offline
post #31 of 54 (permalink) Old 05-19-2019, 12:16 PM
Use the Chrome browser and the "request desktop site" option. The mobile page apparently doesn't show the quote boxes.
post #32 of 54 (permalink) Old 05-19-2019, 04:11 PM
Iamscotticus's Avatar
Heres how to reply to quotes
Iamscotticus is offline
post #33 of 54 (permalink) Old 05-19-2019, 05:25 PM
Got it thanks
Tommyl is offline
post #34 of 54 (permalink) Old 05-19-2019, 09:14 PM
My 2017 does behave as the manual suggests. I put into L today, and it said M1 on the instrument panel. I shifted to M2, and then started from a stop sign. The truck shifted from 1-2 and then revved until I bumped it to 3 and so on.
So it's not really a manual mode, but a selectable low gear like older automatics.
2017 Canyon SLT Crew Cab, 4x4, Short bed, 3.6L
pL9577 is offline
post #35 of 54 (permalink) Old 05-19-2019, 10:27 PM
I guess thats why there is an M on the 6 speed and L on the 8 speed. They function differently?
All that having been said neither 3.6 is an ideal truck engine really. I would prefer the higher torque 4.3 or even the turbo 4.
But still love my truck
Tommyl is offline
post #36 of 54 (permalink) Old 05-19-2019, 11:57 PM
DieselDrax's Avatar
Tow/Haul mode
M and L operate the same, they just changed it on the shifter for 2017+ to be L. 6-speed and 8-speed both.
DieselDrax is offline
post #37 of 54 (permalink) Old 05-20-2019, 05:08 PM
On mine, shifting to L2 does indeed lock out 1st gear, only if Tow/Haul is not active. If Tow/Haul is active, then it'll shift to 1st gear.
Black Diamond is offline
post #38 of 54 (permalink) Old 05-20-2019, 08:46 PM
Jallenb's Avatar
Just passed 500 miles on my 19 and decided to try some diff driving styles. Drove around all day in tow/haul and really liked the difference. I can see why some call it sport mode. Makes me rethink getting a trifecta tune.
JBT and boattail like this.
Jallenb is offline
post #39 of 54 (permalink) Old 05-20-2019, 09:17 PM
Thank you. Is yours a six speed?
Tommyl is offline
post #40 of 54 (permalink) Old 05-20-2019, 09:19 PM
Ok you said L2 not M2 so you have an 8 speed.
Tommyl is offline
Similar Threads
Tow/Haul Mode Not Turning On Gregguz Diesel 7 05-13-2018 11:57 AM
Tow/haul vs Offroad mode ZR2 crankin 2nd Gen Chevrolet Colorado Forum / 2015 GMC Canyon Forum 1 01-26-2018 10:57 AM
Drove in tow/haul mode & didn't have shutter/lag poconojoe 2nd Gen Engines and Technical Discussion 11 01-26-2017 08:40 AM
Tow/Haul Mode and Trailering Package TheProfessor 2nd Gen Chevrolet Colorado Forum / 2015 GMC Canyon Forum 19 08-25-2016 08:51 AM
tow/haul mode jpeloke 2nd Gen Electronics, Audio, and Lighting 3 06-07-2015 09:41 PM
