Dealer labor hours - Page 3 - Chevy Colorado & GMC Canyon
 90Likes
post #41 of 65 (permalink) Old 04-15-2019, 05:51 PM
Tom S.'s Avatar
Originally Posted by T/J View Post
Sorry gents, didnít mean to get anyoneís ire up...
I have a lot of respect for technicians.
I just canít see the justification of the time to change spark plugs. It didnít involve lifting the engine or any crazy stuff. I did have to remove the battery and air intake, but the plugs are all easy to get to. They also charge $40 apiece for the plugs and a fee of like $100 to do a diagnostic check.
My dealer charges for diagnostic tests but deducts it from the bill if you have them do the fix. Otherwise people would come in, get the diagnosis and either fix it themselves or go somewhere cheaper.
2018 Zr2 V6 Crew Cab Delivered 1/10/18
Tom S. is offline
post #42 of 65 (permalink) Old 04-15-2019, 07:08 PM
Originally Posted by White016 View Post
Is there only one engine option on that car? Interesting.
Yep .. 2.0 DOHC
White016 likes this.
dougmac is offline
post #43 of 65 (permalink) Old 04-15-2019, 07:15 PM
Diagnostic time is something nobody likes to pay for even the manufacturer on warranty claims, but it takes equipment, time, and knowledge to diagnose a problem. The equipment, mechanic's time and knowledge is essentially what you are buying when you ask a shop to repair your car whether he is repairing it or diagnosing the problem. It all takes the same resources.
hyperv6 likes this.
dougmac is offline
post #44 of 65 (permalink) Old 04-15-2019, 07:34 PM
The cost of what it takes yearly can be amazing just to run a shop. Fees for tech info to deal with todayís computers cost my buddies shop $15,000 a few years ago and I am sure i5 has gone up since.
Without that info you are pretty dead in the water. Private shops need info on all cars and not just one line like a dealer.
The cost of equipment also is off the charts anymore. Tire machines and balances are just crazy priced anymore and sadly often need repaired and calibrated.
Years ago it just took a basic set of tools and some mechanical ability but that sadly is no longer enough.
hyperv6 is offline
post #45 of 65 (permalink) Old 04-16-2019, 06:38 AM Thread Starter
T/J
This was a tricky diagnosis; odometer said 57,000 miles, service interval said change plugs at 60,000 miles.
T/J is offline
post #46 of 65 (permalink) Old 04-16-2019, 07:09 AM
Which is why I used to go to Autozone for diagnostic test.
post #47 of 65 (permalink) Old 04-16-2019, 07:18 AM
GraniteBlue05's Avatar
Then again . . . .
Yesterday our adult daughter took her car in for "sputtering/dying" at stop signs. I told her it's likely spark plugs, the coil pack or a vacuum leak given the likely issues on her type of 2014 car and that it has over 100,000 miles.
She called me while at the GM dealer and asked if I would come down if she needed me to. Well . .. she already was in for the $97 diagnosis fee. So I just said call me and let me know what they say.
They hooked up the scanner and found cylinder #2 misfire on the 4 banger engine. The tech had already pulled the #2 plug and the service writer had it to show her. Told her it would be $160 on top of the $97 fee to replace the 4 plugs or +$260 with tax to replace 4 spark plugs.
I told her to just have them put the plug back in and tell them her husband is out of town (he is) and she will talk to him about what to do. The service writer came back with, "Well, that spark plug is really "arcing badly" so we can replace just that one for $9.97 for the part and then will just be $126 with tax. "
So how is it that the remaining 3 spark plugs would cost about another $140 ($260 - $120) more since the 10 minute job of removing the coil pack and cover was already accomplished?
I've worked on these cars before and they don't take more than 15 minutes total to pull the coil pack and cover and check the spark plugs.
So understand dealer costs and technician or shop tool costs, but a $140 difference to change the 3 remaining spark plugs? I don't think so . .. .
Then again . . . maybe he gave her a "break".
MaineMan likes this.
2017 Cyber Gray 2WD Colorado LT V6 CCSB- (Z71 Tires & Wheels), Luxury & Convenience Pkgs, Black/Ashen Gray Leather, Bullet Bedliner, ARE cap. Build date: 2-14-2017
13,200 Miles 12-15-2018
https://www.coloradofans.com/forums/attachments/2nd-gen-appearance-body/328415d1540903157-caps-park-pic-1a-sm-edit-50-.jpg
GraniteBlue05 is offline
post #48 of 65 (permalink) Old 04-16-2019, 08:45 AM
MaineMan's Avatar
Originally Posted by GraniteBlue05 View Post
Then again . . . .
I find it amazing how often dealers go for the maximum $$$ fix (scare tactics) within the first look. But once you start to back petal about the cost and rethink your options they seem to have an AHH HA kind of moment and consider a cheaper way to get you the same results.
One thing I always do is wait until the work is done and ask them to produce the worn or broken part(s) for me to examine. You can sometimes tell by their response within the first 3 seconds if you've caught them in some sort of discrepancy. The funny thing is, I'm not a mechanic and most likely will have not idea if the removed part is of any value. But they don't know that. I'm just trying to do a read to determine if I come back to their service dept.
Gusto!
GraniteBlue05 likes this.
Black 2018 Colorado Z71, V6, Crew Cab, 4WD, Purch Apr/2018
THE REAL MaineMan
Previously Owned Trucks:
2017 Laser Blue Metallic Colorado Z71, V6, Ext Cab, 4WD, Purch Apr/2017 Traded Apr/2018
2005 Tan Colorado, 4 cylinder, Ext Cab, 2WD, Purch Oct/2005 Traded Nov/2010
1988 Blue Chevy S10. 4 cylinder, 2WD, Purch Sep/1989 Totaled/Wrecked Feb/1992
MaineMan is online now
post #49 of 65 (permalink) Old 04-16-2019, 08:53 AM
That's like going to WebMD and try to self-diagnose yourself.
They're not diagnosing anything there. They are just taking a guess. Code just give you an area where the fault is at. There's no guarantee that component that the code list is at fault.
Sent from my SM-G960U using Tapatalk
impact, greco2003 and HenryT like this.
2019 white Bison.
Locked is offline
post #50 of 65 (permalink) Old 04-16-2019, 09:04 AM
impact's Avatar
So true! A recent example was a diagnosis of a defective MAF sensor in my sons truck all the while a squirrel had plugged up the filter air box. But at least the code gets you close to the general area in these complex vehicles.
greco2003 likes this.
2015 CCSB Z71 4X4 3.6L LFX Red Rock Metallic
BAK G2 cover - Tekonsha Prodigy controller - Tow Pkg
Weathertech mud flaps - Factory tubular steps
impact is online now
post #51 of 65 (permalink) Old 04-16-2019, 09:34 AM
The code gets me started and at this point half the techs are simply reading the codes and then throwing parts at the code.
post #52 of 65 (permalink) Old 04-16-2019, 11:23 AM
Eric Smit's Avatar
Then again . . . .
He pulled the plug already for the diagnostic. Not trying to justify the labor prices, just explaining. I've had people come in with flickering lights and we pull the lights to diagnose only to find out that cheap bulbs are the culprit. No need to charge someone for replacing the bulbs when they're out already and need to be put back in anyway.
-Eric
I run one of the largest Chevrolet dealerships in the country. If you're having problems with a dealer or have a question about something, I'd be happy to help.
Eric Smit is online now
post #53 of 65 (permalink) Old 04-16-2019, 12:16 PM
Today everything cost too much and to be honest most people are worth what they are paid either.
The deal with reading codes is not really that simple. sometimes it can be a simple parts replacement. Many times it can be a bad wire or high resistance that is difficult to find. You can't see it and if it was intermittent it could be damn near impossible to find. It is not like a bent pulley or broken belt.
Intermittent BCM issues can be down right scary.
CaryBosse likes this.
hyperv6 is offline
post #54 of 65 (permalink) Old 04-16-2019, 01:36 PM
Good point. I've been reading codes since ODB 1 and both the codes and the scanner/readers have gotten better. That's the thing about the codes, they are generated by the programmers to best try and lead a person to hopefully an exact issue, part or area that may be the problem. OBD II is much better but still not all inclusive.
In the case of my daughter's car, it clearly was a #2 cylinder misfire which I could have read with my scanner and come to the same outcome in 15 minutes. Removing the plug and inspecting would then have told the story. Also, if it were a coil, many engines now have packs so the whole enchilada has to be replaced which, actually, helps the hunt and peck to try and narrow down issues at times. In the past with individual spark plug coils, techs might replace one coil and find the issues still is present. Then swapping parts to locate the actual issue results with process of elimination. One of the many reasons an owner may have to return several times to resolve an issue.
There are also, "codes" and DIC displays that come up that are grouped to come up for a number of possible problems. "Stabilitrak" errors and codes are one of them. So, then, it takes some thinking and sorting as to what the actual problem may be.
The programmers have only so much memory resources and sensor data to work with in these automotive modules so they are limited in how much detail can be revealed for any and all potential fails in an ECM/PCM, BCM, etc.
post #55 of 65 (permalink) Old 04-16-2019, 01:49 PM
Tom S.'s Avatar
Hey now - I use WebMD all the time! Just last week, I used it to guide me on removing a tumor from my brain and everything went just fi.. jkfhlghjklrwhtg9qpuiohgdfhal;hgfqrho0[tghqgbnfnbnf, czk!
GraniteBlue05 and cannelg like this.
Tom S. is offline
post #56 of 65 (permalink) Old 04-16-2019, 02:19 PM
"Patient is in V-fib! Rampart, we have lost the victim's pulse, beginning CPR. We're electrocuting the victim hopefully back to stable , Rampart ! ":
Tom S. likes this.
post #57 of 65 (permalink) Old 04-16-2019, 08:40 PM
bogbob's Avatar
I have been buying a new suv or a new truck every 3 years keeping them under warranty and let somebody else pay them high repair bills. Parts and labor cost on old cars are going nowhere but up and the hard part is finding somebody that knows how to fix them.
bogbob is offline
post #58 of 65 (permalink) Old 04-16-2019, 09:00 PM
MaineMan's Avatar
Originally Posted by MaineMan View Post
The Chevy dealership Iíve been going to to 5 years has always been reasonable when it comes to doing work an any of my vehicles. He has a flat rate per hour, about $50 if I remember correctly. If there needs to be additional work addressed he calls first. Never a surprise when I show up to get my vehicle. I know this isnít true for everyoneís dealer. You just need to keep checking out all the dealerships until you find a good one.
The last time I went to get my wheels changed I showed up at 8 AM with a dozen donuts. Will it help getting better service? Who knows. But I did see a dozen smiles!
Gusto!
$50 an hour?! This must have been in the 80s or 90s ?? Most are over $100 now. Around here it's $120 something for Chevys, Cadillac will be higher, Benz and BMW will be higher too.
So I was wrong. I went back and reviewed my invoice. The actual labor charge for this rural area Maine Chevy dealer is $95 per hour. I guess I need to pull my head out of the sand and get out of the 80s.
Gusto!
White016 and Tom S. like this.
THE REAL MaineMan
post #59 of 65 (permalink) Old 04-16-2019, 09:14 PM
White016's Avatar
Gusto!
Still, that is pretty cheap. I'm still in the 80s in many ways :)
White016 is offline
post #60 of 65 (permalink) Old 04-17-2019, 11:41 AM
The Chevy dealership Iíve been going to to 5 years has always been reasonable when it comes to doing work an any of my vehicles. He has a flat rate per hour, about $50 if I remember correctly......
Gusto!
As a fellow Mainer, I'd love to know the name of the dealership you use.
exbex is offline
Similar Threads
Dealer invoiced procedure. Xtrema01 2nd Gen Colorado/Canyon Purchasing and Ordering 3 12-20-2014 09:05 AM
Canyon incentives/supplier pricing - how does it work for the dealer ryandenver 2nd Gen Chevrolet Colorado Forum / 2015 GMC Canyon Forum 18 12-04-2014 06:09 PM
Dealer ordered I Placed A deposit because it was It. The rest of the story. 20WAREAGLE15 2nd Gen Chevrolet Colorado Forum / 2015 GMC Canyon Forum 14 11-01-2014 03:35 AM
Got Clips? Dealer problem Bama Colorado General Truck Chat 13 07-20-2006 11:09 PM
Do you have one of these Dealer can't find one? Ron D General Truck Chat 17 05-14-2006 11:06 PM
