Chevy Colorado & GMC Canyon (https://www.coloradofans.com/forums/)
-   2nd Gen Chevrolet Colorado Forum / 2015 GMC Canyon Forum (https://www.coloradofans.com/forums/114-2nd-gen-chevrolet-colorado-forum-2015-gmc-canyon-forum/)
-   -   What rear axle do we have? (https://www.coloradofans.com/forums/114-2nd-gen-chevrolet-colorado-forum-2015-gmc-canyon-forum/405449-what-rear-axle-do-we-have.html)
Rangerscott 03-04-2019 09:05 AM
Just wondering the name for our rear end is.
404 Not Found 03-04-2019 09:09 AM
Name? Or do you mean axle ratio? The trucks have 3:42 gears except the four cyl gas trucks which have 4:10.
CaryBosse 03-04-2019 09:34 AM
There are 3 (or 4?) rear axles possible on our trucks.
Fully open 3.42 - available on V6 & Diesel
G80 Locking Diff 3.42 - available on V6 & Diesel, required for tow package, standard on Z71. (the availability differed on the Canyon, but it was required for the tow package, standard on the All Terrain.)
Fully Open 4.10 - 4 cyl gasser standard
G80 locker 4.10 - I believe this was also available with the 4 cyl gasser, but tow package not available with 4 cyl gasser. Not sure if there were any other conditions required to get the G80 with the 4 cyl gasser.
I forget, was it Dana or Eaton that made these differentials?
16WhiteColly 03-04-2019 10:36 AM
My LT V6 has the Eaton G80 Locking Differential with 3.42 gears.
DieselDrax 03-04-2019 12:41 PM
Our rear axle is a Dana M220, sometimes referred to as a Dana 46 (which is different than the actual Dana 46 on Dana's website) since it's supposedly a little bigger/stronger than a Dana 44. The new Jeep Wrangler JL uses the Dana M220 rear on some trims as well, however I've seen no confirmation that there is any parts interchangeability between the Jeep and GM implementations. They could have mfr-specific changes that mean we can't take advantage of the aftermarket parts that become available for the Jeep axles.
G80 is the RPO for the locker, it's not the axle model.
Hope this helps!
Rangerscott 03-04-2019 01:01 PM
Hope this helps!
Thanks.
Garrett Stengl 04-15-2019 01:33 AM
I have a 4cyl 2wd 2015 with the 4.10open and really want to swap to the g80. However I cant seem to find any real info online. Any help?
Tom S. 04-15-2019 05:29 AM
Mine is Fred. >:)
bobsunshine 04-15-2019 12:11 PM
I have 2019 Colorado WT 4cyl 2wd automatic with G80 option. Took a while to find one.
Jacqson 04-15-2019 12:49 PM
What model is the front diff?
madcratebuilder 04-15-2019 05:22 PM
Dana 32 aka M200, 7.25" R&P.
Jacqson 04-15-2019 06:06 PM
Thanks man.......:smile2:
Garrett Stengl 04-17-2019 04:41 AM
Anyone have a link to the g80 diff? I want to put one in but can't seem to find the correct one for our rearend
Garrett Stengl 04-22-2019 10:57 PM
Hit up Eaton today. First they said we have nothing on that truck. Then after a second email, I was told to go to the dealer for help. I just want to know what the Pn# is for the g80 option diff. Trying to find it has been fruitless. I want to change out to what everyone witba z71 has or a 2wd with tow package. Its not that hard, but am getting no actual help. Tired of getting stuck because of the posi rear end. If anyone has the info, please send it my way. Don't wanna buy the wrong diff.
16WhiteColly 04-23-2019 11:44 AM
Call dealer parts department, they should be able to furnish a GM part number.
BudRacing 04-23-2019 11:50 AM
There is a sticker with PN on our rear axles. I'll see if I can remember to take a peak at it later.
16WhiteColly 04-23-2019 12:03 PM
That part number may be for the axle housing. May not be for the gear assembly. That is why dealer parts department would be the way to go.
Iamscotticus 04-23-2019 01:14 PM
You would be better installing a complete diff 4.10 G80 than trying to install a Eaton in yours. The G80 is probably made specific to our axles and not av off the shelf. You don't want a 3.42 on that 4 banger.
There is a thread about somebody teasing an aftermarket locking diff for the 'Rados. AEV?
16WhiteColly 04-23-2019 03:16 PM
I agree, because if you are not experienced in setting up gear mesh, you can screw up a lot of money that you just spent. Find a reputable drivetrain shop if you decide to install just the internals.
BudRacing 04-24-2019 10:03 PM
1 Attachment(s)
Gm 27505671
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging v3.1.0 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
