Preliminary ZR2 Bison Part Numbers - Chevy Colorado & GMC Canyon
 36Likes
post #1 of 60 (permalink) Old 09-24-2018, 02:35 PM Thread Starter
I'm looking through the parts catalog and running across the ZR2 Bison parts. As this truck has not been released, these part numbers may change, and most of them are not available for sale, but know folks will be interested. Photobucket is down right now, but all add diagrams later.
Bison Package RPO Code: ULV
Snorkel: 19417719 A/CL (UPR HALF) (AIR Snorkel kit by AEV) (Black) (Install Time 6.0) (4 KG) (AEV Warranty/Product Support (This may be only be available through Canadian dealers, possibly AEV has the exclusive rights in the USA?) no update as of 4/2/19
Spare Tire: 84209638 (WHEEL, SPA (17x8J) (ALUM) (33mm O/S) (120X6XM14 B/C): 4/2/19: Dealer must by 4 at a time, only has dealer pricing, but 4 at retail will be well over $1500.00
Shield Kit: 84352135 4/2/19: $275.00
  • S/GR Skid: 23388798 (SHIELD, S/GR SKID) 4/2/19: $97.28
  • U/B Skid: 84352137 (SHIELD, U/B SKID)
Fuel Tank Skid: 84515405 (SHIELD, F/TNK) $917.10, 4/2/19: part number no longer valid
Fuel Tank Skid: 84510399 (Front Right): $157.36
Transfer Case Skid: 84554642 (SHEILD, TRFER CASE SKID): 4/2/19: $874.42
Reinforcement: 84515406 (REINFORCEMENT, FRM FRT
Shield Kit, U/B SKID(TRANSMISSION SKID PLATE FOR DIESEL ENGINE BY AEV: 19417722
Shield Kit, U/B SKID(TRANSMISSION SKID PLATE FOR GAS ENGINE BY AEV: 19417721
Shield U/B SKID (Supplier Installed): 84510395 :4/2/19: Dealer Cost only, expect retail to be around $700.00
Shield S/GR SKID (Service Lane Part): 84510396 4/2/19: Cost went up to $446.16
Bracket S/GR SKID/SHLD (Service Lane Part): 84347712 4/2/19: Cost went up to $54.76
Bracket, DIFF CARR: 84510398 4/2/19: Cost went up to $519.01
Bracket, DIFF CARR: 84347717 4/2/19: Cost went up to $70.25
Snorkel: 19417719 4/2/19: No cost yet. This is available directly from AEV
Front Bumper: 84579474 FASCIA, FRT BPR (INCLS 18,20,23-25,27-29) (W/LAMP, BULB, COVER, EXTENSION, AND FASTENERS):4/2/19: $2499.97
Front Bumper LWR - LH: 84328530 (FASCIA, FRT BPR LWR -LH) 4/2/19: Only has dealer cost listed
Front Bumper LWR - RH: 84328531 (FASCIA, FRT BPR LWR -RH) 4/2/19: Only has dealer cost listed
#15: Fascia, FRT BPR (INCLS 18, 20, 23-25, 27-29): 84210995, part number changed to 84579474, see above for pricing.
#21: BRACKET, FRT LIC PLT: 84328532 4/2/19: Only has Dealer cost.
#24: Retainer, FRT BPR IMP BAR BLACKOUT CVR (Part of 15)
#25: Bolt, HEX W/Con WA, M6X1X20 (Part of 15) (QTY 6): $10.68
#26: Bolt, M10X1.5X40 (QTY 4): 11588740 $22.84
#27: Bolt, (Part of 15) M12X1.75X30.5, 17 THD (QTY 4): 11562383 $37.24
#28: Bulb, FT FOG LP (Part of 15,29): 15839897 $37.58
#29: LAMP, FRT FOG (INCLS 2 (Part of 15) R: 15780129, L: 15780128 (4/2/19: Only has dealer cost)
#30: Seal, FRT BPR Fascia: 84344891
#31: Front Grille (Anthracite): 84431361 4/2/19: Only has dealer cost, but should be priced the same as the accessory grille
#32: Bolt, FRT GRL (M4.2X1.41X20) (Torx T20): 11570637 (QTY 6) $23.58
Front Bumper Baffle: 23395380 (FRT, BPR SHUTTER LWR)
Front Bumper Support - LH: 84328528 (BRACE, FRT BPR FASCIA SUPT - LH)
Front Bumper Support - RH: 84328529 (BRACE, FRT BPR FASCIA SUPT - RH)
Front Bumper Fascia - LWR: 84394538 (BRACKET, FRT BPR FASCIA LWR)
Front Bumper Bar - LH: 84328524 (BRACKET, FRT BPR IMP BAR - LH)
Front Bumper Bar - RH: 84328525 (BRACKET, FRT BPR IMP BAR - RH)
Rear Bumper: 84580666 (BAR, RR BPR IMP (INCLS 1-5,7-9,11,12,14,15,21-25) (BLACK) 2P (DNS,ULV) (NOT YET AVAILABLE) 4/2/19: Part number no longer comes up
Rear Bumper Bar - LH: 84394578 (BRACKET, RR BPR IMP BAR BPR - LH)
Rear Bumper Bar - RH: 84394579 (BRACKET, RR BPR IMP BAR BPR - RH)
Bison Bumper Rear Auxiliary Light Brackets by AEV: 19417720
Bison Bumper Rear Auxiliary Baja Designs Lights: 19417865
Bison Rear Trailer Wiring RCPT (trailer cap is round): 15317329 $5.15
Floor Liner Mat Package: 84370643 (MAT PKG, F/FLR (INCLS 6,7) (BLACK) (INSTALL 0.10) (2.9236 KG) (FRT) (CONTOURED) (LINER KIT) (BISON) 2P (DNS,ULV) $120.00
Floor Liner Mat Package: 23381376 (MAT PKG, R/FLR (BLACK) (2P43) Crew cab $80.00
Floor Liner Mat Package: 23381382 (MAT PKG, R/FLR (BLACK) (2P53) Extended cab $80.00
My best guess these are for the fog lights to connect to:
2.8 Engine Wiring Harness Junction: 84168217 4/2/19: $332.37
3.6 Engine Wiring Harness Junction: 84317490 4/2/19: 273.87
License Plate Bracket: 11611883 4/2/19: Only has dealer cost
Left Front Fender: 84595238
Right Front Fender: 84595239
LH Tow Hook: 84393529
RH Tow Hook: 84393533
Spacer Front Tow Hook: 11602622
Rear Tow Hook: 84393529 , HOOK, RR TOW - LH, same part number for RH
Decal LH: 84445093 DECAL, PUBX SI (ZR2 Bison) - LH 4/2/19: Only has dealer pricing.
Decal RH: 84445094 DECAL, PUBX SI (ZR2 Bison)- RH 4/2/19: Only has dealer pricing.
Plate, E/Gate: 84211000 MKTB PKG NA (AEV W/Bison Symbol
Headrest (with AEV Logo): 84468113 RESTRAINT,F/SEAT HD(BLACK) - LH, same part number for RH 4/2/19: $104.50 each.
Front License Plate (AEV/With Bison Symbol: 84211000
Front Wheel Liner LH: 84595240
Front Wheel Liner RH: 84595241
Rear Wheel Flare LH (Moulding): 84351718 4/2/19: Dealer pricing only, retail will probably be around $200.00
Rear Wheel Flare RH (Moulding): 84351719 4/2/19: Dealer pricing only, retail will probably be around $200.00
Plate (AEV/Bison symbol): 84211000 E/Gate MKTB PKG NA(AEV W/Bison Symbol)
No pricing has been issued for these yet.
'19 ZR2 Bison EC Diesel
#IWorkForGM-IT Business Analyst
Last edited by emulous74; 04-02-2019 at 10:11 AM. Reason: 4/2/19: Updated available pricing
emulous74 is offline
post #2 of 60 (permalink) Old 09-24-2018, 02:41 PM
ZuluRomeo2's Avatar
Thank you! Depending on pricing I plan to order the Bison skids for my ZR2
ZuluRomeo2 is offline
post #3 of 60 (permalink) Old 09-24-2018, 03:12 PM
wachuko's Avatar
Subscribed as well. In case I end up with a regular ZR2 instead of the Bison. I too want that skid plate set...
Drive safe!
Wachuko
2019 Colorado ZR2 CC-SB Bison Diesel - Build Thread
2018 Subaru Crosstek Limited - Wife
2019 Toyota RAV4 XLE AWD Premium - Daughter
2012 BMW X5 Diesel - Son
wachuko is offline
post #4 of 60 (permalink) Old 09-24-2018, 03:44 PM
bnemmie's Avatar
Same here for the skids. Thanks for putting up the numbers.
bnemmie is online now
post #5 of 60 (permalink) Old 09-24-2018, 07:29 PM
Cwilt's Avatar
Me to!
Cwilt is offline
post #6 of 60 (permalink) Old 09-24-2018, 10:02 PM
I'm thinking about getting the skids too. I also like the front bumper on that Bison.
2018 ZR2 V6 Extended Cab
nvblue is online now
post #7 of 60 (permalink) Old 09-24-2018, 10:33 PM
me too on skids
crappie man is offline
post #8 of 60 (permalink) Old 09-25-2018, 08:49 AM
madcratebuilder's Avatar
I'll bet on the skids being 2X what the supermods or 589's are. I do like the rear bumper.
2017 Colorado ZR2 Deepwood Green Metallic, Ext Cab 3.6 DI DOHC V6 (LGZ) 8-speed auto (8L45).
Midwest Overland Ind, 589 Fab, Warn, GMPP, Trifecta, Nitro Gear, Rhino Rack, Wilco Offset, Smittybilt, Ultra Ranger. Supermod Skidz.
Illegitimi non carborundum
madcratebuilder is offline
post #9 of 60 (permalink) Old 09-25-2018, 10:25 AM
wachuko's Avatar
It is more on the material and process used to make that material... I was hoping these were as strong as those from the aftermarket but less weight...
We will soon find out.
Drive safe!
Wachuko
wachuko is offline
post #10 of 60 (permalink) Old 09-26-2018, 09:22 AM
What did GM call the Bison skids? Hot pressed Boron steel???
I went with the aluminum superskidz mostly for weight. I'm not a big time rock crawler but did want peace of mind for the occasional times I do play in rock pile.
post #11 of 60 (permalink) Old 09-26-2018, 10:10 AM
wachuko's Avatar
Correct...Boron is added to the steel to enhance the hardness level. Added, it provides good abrasion resistance and higher strength than steel alone... what I do not know is how it would compare in weight to the ones you installed.
Drive safe!
Wachuko
wachuko is offline
post #12 of 60 (permalink) Old 09-26-2018, 03:34 PM
F8LZ71's Avatar
Looking forward to seeing these parts available for purchase. That bumper is dreamy for sure.
2018 Canyon SLE CCSB 3.6L - Eibach 2.7" Front Lift | Icon 2.0 rear shocks | 1.5" AutoSprings add-a-leaf + 1" rear lift blocks | DV8 887 179 wheels | Falken Wildpeak A/T3W LT285/70/17 | Custom bed rack |Tepui Baja Kukenam RTT | Morimoto HID | Tyger step bars | LED bed lighting | Nilight 60w LED 4" pods | RotopaX, Maxsa traction mats and Recovery Gear | ZR2 skids |
Build Thread
Instagram
F8LZ71 is offline
post #13 of 60 (permalink) Old 10-02-2018, 09:58 PM
ZRLightning's Avatar
USB-C Receptacle
Does anyone have any info on the 2019 USB-C outlet/receptacle for the center console, interested in upgrading from 2018 USB-type A receptacle.
I would rather use wireless Android Auto and it seems my phone (Orig Pixel XL) supports wireless but the version of Android Auto in the head unit still requires connection through a USB outlet.
Looking for part numbers for new 2019 USB-C receptacle or verification about compatibility with the 2018 wiring harness connection that plugs into the back of the receptacle.
2018 ZR2 V6 HOT RED/JET BLACK
Modified OEM Headlight /Fog light/ Off-Road light Switch,
Sport Bar installed / 4 HELLA Cube LED OFF-Road Lights,
Nilight 7" LED fog/Driving lights
OCD Organizer, 20% Window Tint,
Tonno Pro LR-1085 Lo-Roll Tonneau Cover
Xprite LED Truck Bed Lights
ZRLightning is offline
post #14 of 60 (permalink) Old 10-17-2018, 01:51 PM
New video explaining the Boron steel: https://www.facebook.com/aevehicles/...0198046742544/
ZR2 EMT, wachuko and 1STSFG like this.
travisn000 is offline
post #15 of 60 (permalink) Old 10-29-2018, 12:48 PM Thread Starter
Updated by adding some parts and MSRP when available.
spoonman likes this.
post #16 of 60 (permalink) Old 11-15-2018, 05:45 PM
Ugh. I was parked on the side of the road and got rear-ended by a forklift of all things. Ha ha. Dude put the forks right into the rear bumper and damn near punched a hole through it. So glad it was not 6" higher or it would have trashed the tailgate. Just got off the phone with the dealer, and he quoted me $2500 just in parts to replace the entire rear bumper.....OMG! REALLY?!? At that price, I am for sure looking aftermarket.
Any Idea when the Bison rear bumper will be available? And guesses on the cost?
NoahZ71BabyMax is offline
post #17 of 60 (permalink) Old 11-15-2018, 06:48 PM
I think you're better off getting an aftermarket one.. the bison bumper going to be twice the price of a regular bumper... good luck
radoaleex is offline
post #18 of 60 (permalink) Old 11-15-2018, 11:08 PM
Called AEV today. Sounds like you will be able to order parts directly from them or from GM. Should be available January when the truck drops.
Best price I could find on a stock rear bumper was $650 but that's unpainted and not through a dealership. Add shipping and getting it painted to match the truck?.....1k or more.....and that's doing all the labor yourself.
AEV guy gave a preliminary price of $1400 for the Bison rear.
post #19 of 60 (permalink) Old 11-16-2018, 08:04 AM
FaustZR2's Avatar
What about trying to find a used bumper, salvage yard or someone who has already upgraded to an aftermarket bumper may be willing to sell their stock oem bumper for cheap?
Sent from my SAMSUNG-SM-G935A using Tapatalk
| 2017 Colorado ZR2 V6 | 33" Goodyear Duratracs | 1" RC Level KIT | 1.5" Zoneoffroad Bodylift | 589fab HD Shock Skids | 31 inch 5D Led Light Bar | 120 degree pods with Rago hood brackets | NFAB bed mount spare tire relocation | DeeZee black tool box | Maxliner floormats |
FaustZR2 is offline
post #20 of 60 (permalink) Old 11-16-2018, 11:34 AM
Originally Posted by FaustZR2 View Post
What about trying to find a used bumper?
I've been looking around, but not having any luck. I'm going to keep looking and get a quote from a body shop. I'll know a lot more by the end of the day what I'm going to do. If the Bison bumper was available today.....that's what I'd do.
